The last upgrade I did to the 004 was to widen the bandwidth of the I/V. DSD512 maxes out at just under 25MHz.
The I/V output transistors on my DAC have a transition frequency (fT) of 50MHz, I replaced them with 150MHz devices.
The higher speed also meant a lot of work to stabilize the DAC, the mod took a few hours, spent the rest of the month tweaking and stabilizing.
The work I did on the 004 also meant that it started to expose the limitations of other items of the chain like the DDC and audio endpoint
The work on the DDC is in the SU2 and SU6 threads.
My latest endpoint is the Fitlet3, dual core atom x6000.
Intel's latest 10nm Elkhart 6W core.Fully passive.
Real time kernel for the lowest latency
Fiber optic ethernet, intel NIC, goes directly to the fiber backbone, 2 hops to the server.
Total power is 6.6W with the fiber NIC active
This is a step up from the CoffeeLake NUC8 I was using.
