littlexx26
the reviewer in audiostream says "In my experience, the other DAC that betters the T+A is the dCS Rossini", now people said this DAC is better than T+A. That means this DAC is dCS level?
@b0bb : any suggestions where I can find a DIP socket that's suitable for the LKS PCB, for when I get around to changing the XO?
Bobb what if we swap out Nichicon for Blackgate Capacitors ? 50V-47mF right ?
Hi guys
Anyone of you tried to compare the rca outputs to the balanced outputs to see if there is any significant change in the sound ?
Thanks
Can i ask what your amp is and which cables you are using?some said rca is better than xlr and some said the opposite. i am using xlr because my amp sounds better with xlr.
G'day, I use Mogami gold xlr cables and an Auralic Taurus II amp. This works well for me and sounds great. All the best.Can i ask what your amp is and which cables you are using?
Thanks
Oyaide TUNAMI TERZO XX V2 and Sony TA-A1ESCan i ask what your amp is and which cables you are using?
Thanks
I know that rca is single ended but I want to know if someone have noted differences.RCA is Single Ended and XLR is balanced. The 004 was designed from the ground up to be Balanced with Mono power supply into each channel and DAC , output stage.
