brickears
- Oct 25, 2009
Yeah, but the current max would be ?
Very easily 1a or less. Those Amanero boards don't need a great deal give they can be powered from USB if desired.
What is the amperage for the Power supply card into USB ? I bought a transformer and it has 2x secondary of 15V. I wonder if I should parallel them up for double amperage or ....it would blow stuff lol
I will go with 7V secondary then. Thank you!About 180mA (120mA for card + 60mA for the XOs)
Transformer voltages are specified at full load, 15V seems high you should measure the secondary voltage with no load, I expect it to be between 18-20V, the max DC voltage would be 1.4x that number.
If the AC input to the regulator is too high it will overheat.
I plan on using one from Furutech right after the main one and switch ? With crimped on wires or soldering, but I think for now I need to get a good transformer and a slot to fit him it firstWhitigir, Are you using an RFI filter on the AC input? If so, which?
Thanks.
Oh, I see. Interesting. Isn't that an IEC? I thought the plan was to piggy-back on the existing IEC. Will hopefully look forward to a picture.I plan on using one from Furutech right after the main one and switch ? With crimped on wires or soldering, but I think for now I need to get a good transformer and a slot to fit him it first
furutech-ac-1001
Oh yeah, I am going to piggy back as well on the same socket. Simply parallel the wires into the Furutech filtering and then connect it to the transformer.Oh, I see. Interesting. I thought the plan was to piggy-back on the existing IEC.
Would love to hear your reaction to the change, as I use the USB a lot. Of course I've already insulated the USB socket.
Cheers!
I've just taken delivery of this wonderful machine thanks to all the reviews posted here. Not had much chance to listen yet but I'm hoping it's a huge upgrade on my blusound node 2.
Has anyone managed to get dsd256/512 native working in roon or hq player?
