Gilberto 62
But that "DoP" thing, I still can't find it ...
But you select Asio driver inside Jriver ?Yes, yes, I already put it that way from the beginning ...
In Jriver DoP is in "Output Format", "Output Encoding", "DSD in DoP" but I don't think the problem comes from thereBut that "DoP" thing, I still can't find it ...
Is your windows 7 x32 or x64? The drivers are different for one and the other.Yes, see...
Very important, the drivers you installed were signed (by the manufacturer) ? If they were not signed by the manufacturer, the installation of the drivers must be done in another way.Maybe I should change something there ...My os is Windows7 x64...
I don't know if they are signed just because they are from the manufacturer, probably yes, but if they are not signed to install on windows, it is by a different method. In that case we have to disable the installation of signed drivers.https://amanero.com/drivers.htm .....from here
I don't think that will change anything. LKS drivers must be older.So, do you want me to uninstall and reinstall the drivers ...? Maybe from the LKS page ...?
