Crystek 950x and Vishay naked foil.
L.K.S. Audio MH-DA004 Dual ES9038PRO DAC - Van Damme's double impact?
- Thread starter PitBul34
MartinWT
Thanks. What is the value of Vishay resistor required?
Monolithic
- Jan 24, 2009
It’s dependent on which board version you have. It’s best to remove the board and inspect first. Resistors are on the bottom of the board.
I would also determine the IV peak current as b0bb has outlined in this thread before removing the board.
See post #1743
https://www.head-fi.org/threads/l-k...s-double-impact.840938/page-117#post-14689266
wersuss
- Dec 2, 2015
The 950X , should it be same as stock 100mhz or mhz of oscillator doesn't matter?Crystek 950x and Vishay naked foil.
The one i found on ebay is 122.88 mhz.
https://www.ebay.com/itm/1pcs-CVHD-...h=item3d7383d75c:g:U6QAAOSwQZVcG4sf:rk:1:pf:0
b0bb
- Oct 15, 2014
B0bb,
Could you help please and measure the resistance value in your DAC?
Maybe in my case high value of the resistance is a result of a non isolated heat sink underneath a board, the transistors are not isolated from a chassis. Make sense?
Signal ground on the rca connectors and chassis ground on the power inlet not connected on my Gen1 DAC
b0bb
- Oct 15, 2014
Stick to the 100Mhz, there are internal frequency pre-scaler registers on the DAC that have to re-adjusted if you change the master clock frequencyThe 950X , should it be same as stock 100mhz or mhz of oscillator doesn't matter?
VCXOs have a voltage input that can change the output frequency, you will have to do extra work to negate any noise pickup on the VCXO input to prevent the oscillator output from drifting.
b0bb
- Oct 15, 2014
Replace the IEC inlet backplate, several vendors sell them of the SU-1
https://www.ghentaudio.com/part/dc99.html
Thank you b0bb. Do you think that something wrong might be with my DAC?
Additionally I have a ground loop when I connect with RCAs the 004 DAC to my power amplifier and that makes me wonder if everything is ok.
Both devices are equipped with the PEs. There is no problem with the ground loop when I use XLRs.
In my DAC (the second iteration with the heat sink) the value of the IV resistors are the same as on b0bb's one.
I think that everything above 0.5 is fine. Foil resistors in the IV make a big improvement in sound.
b0bb
- Oct 15, 2014
0.5W...
Double that, you must increase that number as there is no active airflow in the case, this is called thermal de-rating.
Use a 1W rated resistor
Paul Staples
- Mar 29, 2017
thanks!Replace the IEC inlet backplate, several vendors sell them of the SU-1
The original one was with a rated power of 0.5W, but I believe you that a 1W would be a better choice
wersuss
- Dec 2, 2015
Which part for vishay foil resistor?
b0bb
- Oct 15, 2014
TX2575-2 68.1 ohm on a Gen1.
If you have a Gen 2 (the one with the low powered XO regulator) it is 62ohms
This is a 2 module resistor that can dissipate up to 0.8W with no air flow and 1.2W with some air flow.
Double check your unit to determine the exact one.
These are made to order by Texas Components.
This the best grade Z-foil with a non inductive layout
Total: 6 (members: 0, guests: 6)
