Forgisound
Can you describe the sound difference Crystec-Abracon more in detail?
Agreed.Yeh, clocking up or down stream are both important
But isn't the sCLK-OCX10 far more expensive than LKS004 itself, let alone any LKS004 clock upgrade.getting a sotm sCLK-OCX10 to upgrade your streamer is better than changing the 575 in your lks004
The ABLNO is a more aggressive version of the the 575, much better defined top end, much leaner bottom end.It is hard to get Crystek 950X and do you think that this would be ok for the newer 004:
https://www.digikey.com/product-detail/en/abracon-llc/ABLNO-100.000MHZ/535-12347-ND/4240080
It is hard to get other parts for upgrading USB and LKS (diodes, caps etc.).
I just bought one of these used. How can you tell if it's the standard USB or upgraded?
Another question is I have a Schiit Eitr already. Will it provide a benefit to run USB to the Eitr and then Eitr to coax on the DA004 versus using USB in? I'm assuming it would reduce jitter but I don't want to add something to the chain that won't provide a noticeable benefit. Or should I sell the Eitr and get something else? I'd consider $200-$500 range if it provides a clearly audible benefit.
The upgrade has two small stacked boards in the corner where the USB connection is. The upper board is the power supply and has a long wire extended to it from one of the transformers for power.
If you have the upgrade, you probably don't need anything else. But since you have the Eitr, why don't you just connect and listen? Otherwise there are many options as from LKS and Singxer. Do a search, first within this thread.
It seems convoluted to go from usb to spdif then to lks004. It feels more logical to go from usb to i2s directly either via internal amanero or external singxer su-1 etc. Unless you beleive spdif has something over i2s.Thanks for the info on the upgraded USB.
My initial thought was if I have standard USB then Eitr it should be a benefit whereas if I have upgraded USB maybe not so much? I actually have tried listening with Eitr through Coax and then also just directly into the USB port and the differences seem very subtle even though I believe I have the standard USB, so it made me wonder if I might have the upgraded USB.
Just found someone did a review of a lot of these S/PDIF devices and subjectively ranks the Eitr very high, above Singxer SU-1 and F1 and on par with Mutec MC-3+. I don't know how reliably these types of reviews translate to the LKS though.
http://www.basshead.club/spdif-battle-mutec-singxer-lynx-rednet-et-al/
