I guess I can find it on EqualizerAPO right?I just use oratory1990's preset. It's really good. It clears up allot of the muddiness.
Koss KPH40 Utility Review/Impressions
- Thread starter Mad Lust Envy
h8uthemost
- Feb 13, 2011
Actually this site has made it easy:I guess I can find it on EqualizerAPO right?
https://autoeq.app/
Just follow the instructions on the front page. Search for your headphones, and pick the preset with oratory's name on it.
I'm not sure how APO works. I use wavelet as my mobile eq for Android. But just follow the instructions and you should be fine.
Thanks my dude, as long as they can provide the EQ on .txt, I should be able to import it with 0 issues into both the matrix pipeline on HQPlayer and EqualizerAPO.Actually this site has made it easy:
https://autoeq.app/
h8uthemost
- Feb 13, 2011
No prob. Hope it was helpful.Thanks my dude, as long as they can provide the EQ on .txt, I should be able to import it with 0 issues into both the matrix pipeline on HQPlayer and EqualizerAPO.
It was indeed, thank you so much, the kph40's are sounding much better now.No prob. Hope it was helpful.
h8uthemost
- Feb 13, 2011
Right on.It was indeed, thank you so much, the kph40's are sounding much better now.
Crinacle has a kph40 autoeq as well. Not sure if you saw that or not. It's basically the same as oratory's but a bit more bass.
I don't know if you have a Porta Pro or not, but oratory's eq makes it like an entirely different headphone. For the better.
Only saw oratory's profile, gonna check out crinacle's profile because I do enjoy more bass, but the bass on oratory's profile is really satisfying, and tbh, with that profile it seems like a veil was lifted from this headphones, really night and day. In a sense is almost as transformative as John Heaven's EQ profile for the LCD-X 2021, tho Heaven's profile is a lot more complex, 31 filters long, but it comes with instructions to modify the sound to your taste, which is just marvelous.Right on.
Once again, thanks for he tip and I've perused that site some more and there's a lot of profiles I'm gonna try, I was actually looking for a Eq profile for the Meze 109 pro and finally I've found one that's probably going to help them bring them to another level.
