Stevehamny
Quadrangulator, I can't believe I didn't think of this last night: If you want a quick fix to this problem, simply detach that left headphone from the band (it snaps on and off easily, I've done it many times), untwist the cable to straighten it out, and reattach!
This is assuming you're okay with the stock cable, of course. I find the linguine cable on the KPH40 to be perfectly adequate and much better than the cheap memory-prone cable of the KSC75, but that's your call. I wouldn't blame anyone for doing the MMCX mod because it's easy and why not?
