I have it. It’s a good complement to my EW200. I noticed you have that one as well. I also have the Moondrop KXXS; I think the soundstage is wider and maybe slightly deeper/similar on the ZSN Pro 2. Even though the graphs out there indicate bass overall should be more on the ZSN Pro 2, it has more control and less bass bleed into the mids than KXXS imo. Treble can be a bit spicy depending on the tips you use; Moondrop Spring tips and JVC Spiral Dot tips elevate the lower and upper bass a bit (I think it helps to mask some of that treble harshness) - they measured very similar on my MiniDSP EARS. It’s definitely not as harsh as ZSN Pro X.Has anyone else got the ZNS Pro 2?
- Thread starter bhazard
superuser1
Indeed i was surprised at the balanced tuning and as you rightly pointed out the spiral dots do what they are supposed to do.I have it. It’s a good complement to my EW200. I noticed you have that one as well. I also have the Moondrop KXXS; I think the soundstage is wider and maybe slightly deeper/similar on the ZSN Pro 2. Even though the graphs out there indicate bass overall should be more on the ZSN Pro 2, it has more control and less bass bleed into the mids than KXXS imo. Treble can be a bit spicy depending on the tips you use; Moondrop Spring tips and JVC Spiral Dot tips elevate the lower and upper bass a bit (I think it helps to mask some of that treble harshness) - they measured very similar on my MiniDSP EARS. It’s definitely not as harsh as ZSN Pro X.
ScrofulousBinturong
WhatNow that's a graph like a roller coaster! Congratulations KZ, I've never really seen that before
Tak to je milé stretnúť tu ďalšieho Levičana. Ktovie koľkí sa tu ešte vyskytujeme? Srdečne zdravím...What
Nimweth
I have been testing the PR3 via a balanced 2.5mm 25 Ohm adaptor. Wonderful with a smoother and somewhat warmer and musical tonality without losing the technical performance Definitely recommend trying this if you have the PR3.
superuser1
This on the ZSN Pro 2 sounds pretty good.
ScrofulousBinturong
WhatTak to je milé stretnúť tu ďalšieho Levičana. Ktovie koľkí sa tu ešte vyskytujeme? Srdečne zdravím...
When I click on your home town in your profile, it shows my hometown. I thought that matched reality...What
iscorpio71
ScrofulousBinturong
Has anyone owned or tested both the AST and the AS24? Bonus points if you've also tested the BA10. I'm curious about the differences.
Nimweth
I have not heard the AS24 but you may like to see my review of the AST which has a comparison to the BA10:Has anyone owned or tested both the AST and the AS24? Bonus points if you've also tested the BA10. I'm curious about the differences.
https://audiosolace.com/kz-ast-review/
ScrofulousBinturong
Indeed, thank you so much!I have not heard the AS24 but you may like to see my review of the AST which has a comparison to the BA10:
Opinions on AST are quite polarised. I personally consider them to be the worst KZs I own. They have heavily muddy bass that bleeds into the mids and a total lack of sparkle in the highs...Has anyone owned or tested both the AST and the AS24? Bonus points if you've also tested the BA10. I'm curious about the differences.
Nimweth
KZ Symphony has arrived. I had a quick listen before setting them up for burning in and the mids in Elgar's Pomp and Circumstance No 4 were a little distant. Staging was very good and treble extension similar to the PR3 but not as bright. Bass was excellent, with very good ambience and decay. Hoping the mids will improve after burn-in.
jant71
- Feb 19, 2005
Thought this would be fun to post here...
Total: 27 (members: 5, guests: 22)
