May 25, 2023 at 12:35 PM Post #61,666 of 64,225
I'd reccomend to everyone using the KZ planars to upgrade to the KZ 784 core cable. I've let two non-audiophile friends try them blind and they claim to hear an improvement with the 784 cable. A nice bonus is the fact that the cables make the PR2 easier to drive as well (higher conductivity).
What do you think about KZ 1064 cable. Did you try it?
May 25, 2023 at 1:04 PM Post #61,667 of 64,225
Hard to see the back of IEM, but it seem like driver is not covered with the mesh, meaning it is later/changed batch.
Here are some examples posted previously of newer changed batch with damper now in the nozzle, instead on top of the driver.
Please take a photo at the same angle as the following without the eartips mounted, if it's not a bother that is?
I'd like to get a look at how and where the damper is mounted in the sound tube.
Thanks.
May 25, 2023 at 2:40 PM Post #61,668 of 64,225
Ah I just reshared those pictures (thanks to @DaveLT ), my set is still coming since 27th of April.
May 25, 2023 at 4:06 PM Post #61,669 of 64,225
Would have been nice if PR2 had the same cable as PR1 Pro.
I been thinking on pairing PR2 with pink AK Yin yoo 6 Core or NiceHCK C16 NX7 since I have those laying around.
  • NiceHCK-C16-3-2-5mm-3-5mm-4-4mm-to-MMCX-2pin-NX7-QDC-Pure-Copper.jpg_640x640.jpg
May 25, 2023 at 5:01 PM Post #61,670 of 64,225
Another package on the doorstep this morning. KZ PR2 arrived! They were ordered on April 27 and mine don't have the mesh over the top of the magnets. On a phone they can reach uncomfortable levels but struggle below 75% volume. BTR3K, FD3 and R2 can drive them okay but not as well as SR25 (surprise). So all up, these are hungrier power wise, than P1Max! I haven't tried them on a balanced cable or tip rolled yet. OOTB these sound simply amazing for the $29 they cost me. Many thanks also for the KZ Global Store code, to whoever originally posted it!:ksc75smile:
Congrats, sounds like you got lucky on the chifi lottery :)
May 25, 2023 at 5:03 PM Post #61,671 of 64,225
Finally got my PR2, I’m not super experienced with IEMs but my initial impressions are that you have to spend like $300 to get this sound quality in over ears
May 25, 2023 at 5:09 PM Post #61,672 of 64,225
Has anyone (who has received their PR2) paired it with the balanced 4.4 output on the RU6? Interested to know if the RU6 powers it well enough. It powers my DT770 Pros (250Ω), but I know that planars can be just as hard/if not harder to drive.
May 25, 2023 at 5:12 PM Post #61,673 of 64,225
I skipped on the foams when I first got them too for comfort reasons but have grown to like them. The CoreIR tips made them a bit too bright.
Yup, Quarted has the PR2 v2. No driver mesh and denser nozzle mesh.
Still waiting for KZ to ship my v2 pair.
So far sounds like PR2 v2 (should be PR3, to be fair) is received well and easier to drive. Eager to hear v1 vs v2 A/B comparison.
May 26, 2023 at 12:30 AM Post #61,674 of 64,225
Nope, first it heard of it. I already have multiple cables and the main appeal of the 784 was its price/performance so I may or may not get it in the future depending on need.
While I know that cables can (and do) make a difference. The main benefit you'll get is swapping from a bad to decent cable. Decent to expensive tends to be negligible, at least until you go to the category of cables aiming to colour (read degrade) the sound which I'm not interested in.
I've seen people spending thousands on cables to cope with their bad (but expensive) iem purchase, don't go there.
You can spend thousands and get a worse sounding iem than the PR2. I would compare the PR2 to the Euclid but unfortunately I've never had the opportunity to try it yet. But hey, I expected a better extended Zetian Wu Heyday with my PR2 purchase and it delivered so that's great.
There remains the fact you can't buy the original PR2's as tuned by HBB anymore but we shall see how they compare. Hopefully i don't get a bad unit.
May 26, 2023 at 11:51 AM Post #61,675 of 64,225
My PR2 from the Global store arrived yesterday. Revised version. Listened to a few tracks on the Fiio M7 using the Tempore BHD 2.5mm.
The last KZs I bought were the CRA and the ESX when they $8/10 CAD respectively. Like most of my KZs they pretty much just take up space.
Aria and the QoA Gimlet are my DDs at this point. Just from an initial listed. I might add the PR2 to the list.
May 26, 2023 at 12:46 PM Post #61,676 of 64,225
Here’s another data point.
Ordered Apr 26, finally showed up today.
Broke my self-imposed moratorium on budget sets with this purchase. Expectations were low and at some point I wished I’d cancelled it. But it’s surprisingly good. Pretty even-handed tuning and decent technicalities for a planar straight out of the box, stock everything. Is this what I missed while I was away? Can’t say I’m regretting it so far and I haven’t even started tip or cable rolling.
May 26, 2023 at 2:16 PM Post #61,677 of 64,225
Am I correct in not seeing a dampener in the sound tube? 🤔
May 26, 2023 at 3:34 PM Post #61,678 of 64,225
Today arrived KZ PR2 from KZ Global. Thanks for the discount coupon. Unbelievable what you can buy these days for 35€. Unbelievable what power it needs. Forget cell phones, weak dongles, even mediocre performing DAPs. What you will hear from them is not even half of what the PR2 can really do with a decent dose of power.
May 26, 2023 at 10:12 PM Post #61,679 of 64,225
So I've been trying them (pr2) for a couple days and they weirdly sound the best directly from my phone(poco x3 pro), it's like the nicest shallow V shape...
I have the tempotec sonata hd pro and you have to trick it with a 3.5 extension or it just doesn't give you enough power and even then they sound a bit too crispy in the top end, tried them on my liquid spark and same, guess the combination of sensitivity and impedance play well with my phone's crappy internal dac lol.
also tried them with a different iem cable for the mic and I straight up lost the bass from the amps guess they didn't like the 4 poles
May 26, 2023 at 10:53 PM Post #61,680 of 64,225
Best from something more powerful, but still sound good for $35 from a phone. I haven't been as impressed by a shift in performance/cost since CRA. I'd still happily recommend these to someone starting out, on the basis they will step up later with a better source.:ksc75smile:
