People say that if you EQ PLA13 to Timeless bass, the thing can compete with dioko.Yesterday (after a short 10 days since ordering) the CCA PLA13 arrived. My first impressions are quite mixed. The cause is the bass. These are not simple bass headphones, these are bass monsters with absolute bass dominance deep into the sub-bass level. The bass is pronouncedly STRONG physically present, which in the case of planars of not very large size will certainly catch many by surprise. I don't consider the mids to be heavily bloodied by bass, they are relatively clean, but they are obviously in the background, as is usually the case with V tuning (L tuning is relatively easy to achieve with appropriately chosen tips). The midrange suppression stands out in direct comparison with the vocal-tuned KZ AS16 PROs.
Beware, PLA13 are quite demanding on the power of the amp, better forget about using it with a mobile or a weaker dongle right away (balanced output + high gain are welcome).
If for some reason you cling to KZ/CCA, I consider the AS16 PRO in the same price range a clearly better and more versatile choice.
KZ screwed up this tuning, clearly
