PhonoPhi
I have literally "undusted" my impedance adapters of 20 and 75 Ohm. I also have a resistor box to get any arbitrary values.a little PSA, KZ eartips is not that good.
for ESX, if the bass a bit obnoxious, you will get better experience with it if you use widebore eartips like KBEar07/AET07.
Apparently it will sound a bit better with Impedance adapter (18~-30 ohm), or using high power source like TK-2?
And it seems the target IEM for AS16Pro is QDC V14, i wonder if someone here have heard it and can compare
Quite a bit of a limitation is that all impedance adapters, that I am aware of, are unbalanced, and the circuit with two resistor box is rich. Perhaps, another audiophile direction, more meaningful than cables at least
Anyhow, sorry for the digression, testing unbalanced with my Tempotec E44 and the recording cited above: it surely sounds different - the bass is more suppressed and mids are more emphasized with 20 Ohm for more leanness and clarity. At 75 Ohm, high-mids feel even more prominent, 75 Ohm may be too much.
I prefer the original tuning, the lean BA bass lovely tuned warmer, I am not giving it back. I have Dioko for the lean signature with its undertuned midbass (I am not adding midbass there either).
Then, in my opinion, all all-BA IEMs sound differently with different source impedances, and all are very amenable to digital signal processing, including equalizers.
So equalizers are arguably a much simpler and more flexible and instructive way to enjoy different tunings other than the stock signature.
P. S. It is possible to speculate that KZ used 18 Ohm source impedance to produce the graph more likeable by "graph aficionados" and then the warmer tuning for the most of the listeners - actually, a smart strategy and a good crossover design (AS10 are surely different, for instance).
