Just playing with some mods on the EDX. Funny that you can basically get the VK4's curve with a smidgen of cotton stuffed into the eartip. Wondering if the VK4 uses a sort of foam/filter inside of the nozzle and EDX is just filterless. I'd try opening the EDX's nozzle grill to check it out, but it isn't popping off with my prying edges method with a sewing needle, it feels like the grill is glued.
The results:
As it was mentioned before, fully covering the nozzle with micropore completely mess up the sound. Covering 50% works better depending on your goal but I think I'll retire the micropore as a mod for taming upper-mids/treble. It ages like milk, so after some weeks your result may vary since the tape degrades quite fast and the tape's glue gets messy onto the nozzle.
I'm really liking the cotton stuffed into the eartip, your result will vary a lot depending on the quantity of cotton, but it takes less than 1 minute to perform the mod, and usually, it won't muffle the bass so you can get pretty good results if you don't overdose the quantity. It won't get gummy after some weeks just like micropore tape, the trade-off would be it works optimal only with narrow tips, so if you like wide-bore this won't work very well.
I think foam would work well too, but a smidgen of cotton is more reliable to achieve the same modding result, each foam has its own characteristic and thickness, so depending on the foam your result will vary a lot.
(for example, this one is too thick and dampens much more than the "animal foam" posted early)
