Very good points.
Tips can make a huge difference for fit, seal and tuning.
I do have my "drawer" of tips.
Having some technical experience with woodwind acoustic, especially clarinet barrels (talk about weird collections...), my preferred way way with the tips is to restrict minimally at the tips using wide bores, such as Spiral dots and similar.
I found for the narrow tip bores, the insertion depth starts to matter more (what is observed in measurements with couplers), so it is more sensitive in how it works.
Foam tips do not bode well with me.
Listening volumes also matter, as it was noted here.
I listen at low volumes, so treble is more tolerable (the Fletcher–Munson curves) and ZAX is more preferable to CA16.
At higher volumes it can be reversed. (My model case is Final E3000 - at my usual listening volumes, it is all about midbass... But then trying higher volumes, I can at least appreciate what others like about E3000
CA16 is definitely appreciably dampened by some filters based on its sensitivity values compared to ZAX and other KZ/CCA.
If treble is too much, it is always possible to dampen it with different foams - this site is a great resource for a practical advice on such DIY projects.
Dampening to your tastes is always easiee than to " undampen", IMO.
