Viber
- Jan 28, 2008
For what's its worth, tws are more comfortable than a trn bt20 and an iem especially if you wear glasses and a mask. I use tws sets far more than my trn bt20, which is almost pemantly attached to a an iem that cannot be named here. I think all but the new ones would damage the kz type c connectors too. Which is a consideration.
With glasses and a mask you can just use the regular BT adapter with the cable and peel off that STUPID "memory" metal and rubber they attach to behind the ears part of the cable.
_________________________________________________________________________
Isn't the Fiio UTWS1 a better product than TRN BT20s Pro? or will it not fit KZ IEMS ??
