Do you have a budget? And is it only a KZ IEM u are looking for?
KZ is undoubtedly the market leader at the $30ish - $50 USD region, and they were my first foray into CHIFI, but there are other good affordable CHIFI brands to consider too. And I gotta say above the $50 price bracket, there may be better stuff than KZs.
i sold my Tape after i got the T2+. between my T2 Pro (for low volume) and Etys(for higher volume) , there's not much that the Tape can add. T2Pro for me sounds better in similar scenarios to the Tape, and i can get the ZS10 Pro/ ZSX in the same ballpark as the Tape with EQ. i hope the new Tape 2 would be good though
U might wanna read about stuff like:
- KBEAR KB04
- KZ ZS10 Pro
- KZ ZSX
- CCA C12
- TRN V90
There's a new CCA C10 Pro that just launched, but haven't seen any reviews about it, but one to keep an eye on. If u can up your budget a bit, do consider the iBasso IT00. There's actually a big Aliexpress sale now going on, so it is a good time too to get stuff, though better check on how are the transit times to your country in view of covid.
- KBEAR KB04
- KZ ZS10 Pro
- KZ ZSX
- CCA C12
- TRN V90
Yep I would think a V shaped type signature with good technicalities should suit rock, so those would be my go to (they are multi BA/hybrid type IEMs).
I'm about to gift my Dad a Bluetooth cable for his KZ ZSN Pro. Which KBear S1 variant should fit better on the ZSN Pro's Paragraph C cable? "2 Pin" or "TFZ" one?? Thanks
Absolutely!
That would be as if standing right next to cymbals - high overtones are there and overwhelming.
High overtones decay fast, so over some distance cymbals are more listenable.
I listen to strings, recently I was particular enjoying recordings of Chinese string instruments with plucked strings: konghou, guzheng.
Less dampened BAs make those instruments sound amazing, as if you are immersed into sea of strings, and pentatonic makes it also easier for clashing overtones.
Works well with chamber string instruments as well.
