PhonoPhi
The link is to the cable, for which many options are available including QDC that works with KZ/CCA.Thanks, although the link you provided isn't for a balanced cable (at least it doesn't say balanced).
Also from what I'm seeing, only 2.5mm and 4.5mm cables are available in balanced, not 3.5mm. Is that right?
I don't really *need* balanced as my IEM will be plugged into a behind-the-neck bluetooth cable, not a DAC/AMP. however it will be 3.5mm.
I use largely 2.5 balanced (3.5 balanced is very rare), these cables I measured and can state confidently, including the one in the link.
Others measured non-balanced 3.5, no specific concerns were raised, as far as I know, but again I summarized my experience.
