While their IEMs seem to be competitive by sound, there are quite a bit of problems with QC.
I personally have problems both with the IEM and cables not to try them further.
Guys, i've been out of this world for a while now, i'm looking to get back into it, is KZ still the best cheap hi-fi earphones? I have the AS10, but i'm looking to get something new, better and with more bass.
Maybe if you could let us know your answers for these questions, then the community can finetune their recommendations better:
1) What is your preferred sound signature - V shaped, neutral, basshead, treblehead, midcentric etc
2) What is your preferred music genres?
3) Budget?
4) Do u need isolation? - will this set be used at home or on the go?
If from your initial post, u like more bass in a KZ, then maybe u can consider the KZ ZSX (terminator) and KZ ZS10 Pro (the former is a succesor of sorts to the ZS10 Pro and has better timbre and technicalities, though fit may be worse than the ZS10 Pro).
TBH, KZ were the pioneers in the CHIFI game, and they are still one of the better CHIFI below $50 USD, but if you are buying CHIFI around the $100 USD mark, there are better brands out there. KZ lately seems to be pushing their development down the wireless rabbithole, haven't had any wired releases since the KZ ZSX.
ZSX and V90 are my picks on sub $50 IEM, they performing great both and have very great value. They are side grade to each other, just come down to personal preferences, if you are into V shaped with more sub-mid bass, go for V90, if you like more balance presentation go with ZSX, technicalities are on par more or less. Aside from that on sub $50 you may check on TRN BA5, BLON BL-03, BQEYZ KB100, Jade Audio EA3. I can easily recommend those IEMs and still enjoying them.
Anyone using a balanced cable on their ZSX? Is ZSX actually going to benefit from more power over balanced (using BTR5), or is it really much of a muchness?
I have my ZSXs on balanced from both the ES100 and more often from my R5. I think they benefit from more power, it helps with the soundstage and instrument separation. I can only get to about 40 volume on high gain on the R5, I think high-gain has better dynamics than low-gain. But that's just my take -- I have everything on balanced other than a couple of pairs of hard-wired IEMs and cans that can't do balanced without modification.
# For me ES3 is not well tuned, mediums do not sound natural (ES4 sounds very natural)
# I do have AS10 (all BA) very good overall detailed sound, bass very pure and of good level, trebles a bit low level for me, but probably good for young people
# ZSN very very good for a two drivers. bass has good punch, trebles good, mediums a bit backward but ok
# C12 (nearly idem as ZSX) bass have more punch than AS10. Mediums have a good level, trebles too, lot of details everywhere, the best I have.
I would preffer
AS10 for classical, but very good for everything else
C12 better for electronic music for the punchy bass and C12 better than ZS10pro and nearly same price.
ZSN best of all at this price, but less details than multi drivers
Ditto with the exception I only use mine balanced thru my ES100's and balanced DAP's Most of my iem's cases have both cables inside them these days at least the ones I deem worthy of having both
@jeromeaparis I like your breakout however mine is with BA10, ZSX and ZS6's! You know we all hear them a little differently but for my ears these three KZ's pretty much match your descriptions verbatim No matter how you look at any of these they all fall under the Affordable Luxury category
