TwinACStacks
Wait, do people actually think burn-in does something?
JMHO and I'm sticking with it.
Try some silicone tips which are very soft and have large opening + brass nozzles Imo ED9 doesn`t require so perfect sealing to sound as good as it sounds. Heck, eisenbrich even tried them without nozzles and said it was good ;D
If You don`t like or use Your GR, then it is pretty good cable donor to ED9
Also, I bought a pair of KZ GR at the same time, more for the nozzles than anything else. However, it seems like the threads on the GR nozzles aren't quite the same as on the ED9, so I can't screw them all the way in.
This is kind of frustrating, as I too have ordered a pair of GR, just for the red nozzles, based on the claims of two posters in this thread.
Also, although there are claims that the red GR nozzles are best in the ED9, no one has stated exactly what improvements can be expected. Only general statements that the red filters are the "best."
seems You have different red filters. Yours have no hole? I have holes in red filter.
it seems that the threading on the ED9 filters is slightly thinner than the filters on the GR..
My gold filters on the ED9 have to be installed a certain way, as one will not screw all the way into the left side. Brass filters are fine.
I guess that's one "downfall" of such an inexpensive product. Personally, I don't care, but for those who bought the GR for the filters and ran into this issue, I get where you're coming from.
