Same opinion here . Furthermore it sounds steely and the mids and highs lack air ot transparency .I have used KZ ZSN quite a lot and I can not get used to it either, it has a very aggressive sound for my ears. I always end up going back to tin t2
- Thread starter bhazard
LaughMoreDaily
Everything needs burn in, including a romantic relationship.Does the zsn nerd burn in?
LaughMoreDaily
You go back to your T2 as well or do you have another IEM you prefer? It's interesting hearing these negative comments about the ZSN while I await two of them in the mail. I want to put "Wrong Address - Return To Sender" and see a refund on my credit card in a couple months after waiting a couple months for them already.Same opinion here . Furthermore it sounds steely and the mids and highs lack air ot transparency .
The zsn sounds better with some surround mode if available in your smartphnoes or sound card .You go back to your T2 as well or do you have another IEM you prefer? It's interesting hearing these negative comments about the ZSN while I await two of them in the mail. I want to put "Wrong Address - Return To Sender" and see a refund on my credit card in a couple months after waiting a couple months for them already.
But overall its lacking natural sound or musically not inclined .fyi i owned the trn v20 and its better at being musical than zsn .though their soundstage is not so wide they have a bit of depth .
1clearhead
- Apr 5, 2013
Haha!...I won't quite call the ZSN a nerd, since these guys are very lively and constantly likes to party!Does the zsn nerd burn in?
LaughMoreDaily
What's the best way to color the silver backed ZSN black?
Goth: Nail polish?
Goth: Nail polish?
voicemaster
Just received my TRN bt20 and I am loving it. I am loving the range this bt20 has over my bt3. WIth my bt3, if I were to go to my bathroom (about 15 steps away with walls) the signal will cut in and out; with bt20, no cut out so far, even when I went to the kitchen (about 25 steps away). Connected to my PC with no problem at all (the instruction manual is a joke tho). It is very comfortable and fit my ears like a glove.
Zerohour88
A few users not liking it doesn't mean its bad. Its all about preference. You buy a lot of stuff and then you slowly find your preference for sound signature, compare them to reviewer/other users and then verify who to trust according to your preference.
it just basically means people who don't like the ZSN have to probably avoid any future recommendation from people who liked them, that's all.
assassin10000
Goth: Nail polish?
Swap it with a black backed one.
Otherwise it depends on what your willing to do/pay. Anodizing, powder coating, various paints (model, nail, etc) or even just using a black sharpie.
LaughMoreDaily
I was thinking of swapping the silver back for a black one but you need a specialized "screwdriver" no? The same one used for opening apple devices? Can I buy this just by itself or would I have to go to a cell phone repair store to do the swapping?Swap it with a black backed one.
assassin10000
I don't have my ZSN yet, so I can't personally confirm but others have said it's the 5 spline Pentalobe screw like the apple ones.
You can buy the screwdrivers or bits if you already have an interchangeable screwdriver. A local electronics store may even carry what you need in stock if you don't want to wait for shipping.
LaughMoreDaily
I will ask my local electronics store but I just realized I would still be stuck with an ugly silver backed ZSN when interchanging with a different bodies color.I don't have my ZSN yet, so I can't personally confirm but others have said it's the 5 spline Pentalobe screw like the apple ones.
assassin10000
Definately a Pentalobe screw, going by pictures (from head-fi reviews). From @B9Scrambler
You could look at picking up a bit of 'Aluminum Black' by birchwood casey. Originally made for turning aluminum scratches/imperfections black on anodized gun parts. May have to sand (or bead blast) the surface of your silver covers for it to work. Only works on raw aluminum, if there's a clear coat it won't work.
https://www.amazon.com/dp/B002JCW2CG/
https://www.amazon.com/Birchwood-15121-Casey-Aluminum-Touch-Up/dp/B072LT4HCZ
I replaced the ZSN stock brown copper cable with the EZ Silver/copper mixed cable and the sound becomes different... it becomes more deep and V shaped .... and some the mids and treble become less steely and become more recessed and in the right shape...overall more transparency and sound stage .. becomes more similar to the Qt2....there seems to be a significant difference after the cable change...Haha!...I won't quite call the ZSN a nerd, since these guys are very lively and constantly likes to party!
maybe its a stock cable problem ....anyway not sure if the cable will burn in ?
link to the cable:
https://www.aliexpress.com/item/KZ-...351.html?spm=a2g0s.9042311.0.0.30994c4d16q6jo
LaughMoreDaily
I think that cable is crap. Can someone else please compare it to the KZ 8 core silver plated and TRN 8 core Skunk cable? I don't want to seem like I'm blowing smoke, but it's a waste of money. A big waste of money.I replaced the ZSN stock brown copper cable with the EZ Silver/copper mixed cable and the sound becomes different... its more deep ...and wide ... and some the mids and treble become less steely and become more recessed and in the right shape...overall more transparency and sound stage .. becomes more similar to the Qt2.... maybe its a cable problem ....anyway not sure if the cable will burn in ?
