Podster
my ZSN(purple) just arrived a couple hours ago, and first impressions... not impressed.
swapped out the tips to foam since its i dont like silicone,
comfort is fine, not as comfortable as the es4 though,
my main criticism is that the vocals, claps, cymbals & saxophones felt a bit too forward or harsh for my taste
and because it has vent holes everywhere, i can hear the wind whistling (like when you cover your ears with only 3 fingers albeit quieter) though you wont hear it once the music starts playing
the bass is about the same compared to the es4 & stronger than the zs6, its also a pretty loud iem too, which makes it easy to drive
imaging is comparable to es4 & soundstage feels wider than the es4, the es4 is a very intimate sounding iem for me
and thats about it really, for now i dont really like it, it just feels average... maybe because i havent burn them in enough or its just not my sound profile, personally i prefer the es4 compared to the zsn
if i want to be even more unfair, i compared it to the V80, and this thing just get steamrolled by it in every single way (except the design)
i might make a new impression after i burn it in for a whole week
Three suggestions!
1. Keep Tip Rolling
2. 90+ hours burn moderate volume
3. Knowing the efficiency and lean to brightness use a tad less VU
If that does not bring them around for you I'd suggest staying away from any bright signatures I'll agree on the looks take for sure
