Well, that makes two of us. I think both are capable of exceptional detail retrieval and I have no issues with the treble on either.
I also noticed that there is no ES3 review yet. I think it deserves a proper review even though it is similar to the ZST. The differences are subtle, but I can definitely appreciate those differences (slightly more presence in the bass, a tad more warmth in the midrange and highs that are focused more toward lower treble than upper treble). They're a lot of fun.
Thanks for the warm welcome. Little by little it makes the world a better place
I've lost the hope of getting what I want from KZ after buying ZS1, 2, 3, 5, 6 and ZST. When you get ZSR please compare it with ZS6 as far as piercing treble and good base are concerned. It's a request.
@Podster I'm guessing there is a teensy microdriver in there, but the camera is making it look a bit stubbier than it should be? I'm not going to play since I've got enough KZs, haha.
I guess you're right. I am expecting Ostry KC06A and than I'll stop searching for IEMs for a while. Actually I am not a fan of IEMS especially when compared with Meze 99 Classics which I listen in when at home. I thought I'd find something suitable for the street conditions but in vain. Sorry for the partial off-top.
Perhaps, you should consider the BossHiFi B3 (wood) or Urbanfun Hybrid. Maybe even the BossHiFi S1(blue). The S1 wires are over-ear and the B3 wires are not. My B3's have no microphone while my S1's do have a microphone.
I have Urban fun. But still lacking bass.
Yes, I understand that but if I had less treble in ZS6 I'd be almost satisfied for the street conditions. Thus, I am playing tips (tip rolling) including spinfit and blocking the drivers with fabric. For now with little success. I am getting used to ZS6, though. May be because I am still having a cold it's not THAT piercing now.
I hope so too. But it did not help with ZS5, though. Could be because I removed the foam from ZS3 and put it to the ZS5 nozzle. May be I will try another type of foam or tea bags or stuff like that.
I've a question. What is the best option to have for prominent bass frequencies - small or middle or large size of the tips? I am not talking about the comfort but about the possibility to get more bass.
If I insert tips deep inside my ear and hold them with my hands there inclined at a certain position I am having the bass I am satisfied with. The question is how to keep the earphones in this position. If I found an answer to this question I'd be happy and satisfied. I don't consider the idea of custom molding though. It hurts the ears after hardening. At least I read some reviews about that.
Perhaps, you should consider the BossHiFi B3 (wood) or Urbanfun Hybrid. Maybe even the BossHiFi S1(blue). The S1 wires are over-ear and the B3 wires are not…
As mentioned above I love wooden IEMs. I wear my BossHifi B3s over ear. Just switch left and right so that the nozzles point the correct way and can be inserted into my ears. I don't mind when the violins are on the wrong side of the stage.
If you decide to try the Urbanfun Hybrid be careful with your purchase. They make a beryllium DD that looks similar (perhaps identical) and a number of sellers on Aliexpress.com aren't very good at distinguishing between the models. Some even lump them together in the same product page as 3 'color' choices: the green hybrid, black hybrid and the beryllium DD version.
Hey @bsoplinger , I find the K4's to sound 5 times better than you $9.99 Skull Candies at Best Buy not to mention 10 times better looking. IMO worth $20
