EISENbricher
Wokei! Horrible things have happened. My ANV's left channel has died. Le sigh.
Get new ANV? Too cheap now lol
It looks same with the preview picture, anyone know?
Just broke down and ordered the ED8 (blue). Couldn't resist the $7 price tag.
I'm just about to order the ED8 togheter with the DT5 pole edition for 14.80 lol
Does the dt5 pole edition worh it?
If you're spending $7 on a KZ IEM does it make sense to use expensive foam tips? Even if you can afford it, there are better (and more fun) alternatives. See this old thread:
http://www.head-fi.org/t/383917/how-to-best-custom-tips-for-iems-ever-imho-with-pics/195#post_11075327
I used a silicon tip from a T1 - narrow bore and converted it into something similar to a Sony foam $$$ hybrid tip! The foam is INSIDE of the silicon. This really makes my KZ's shine - EDSE (and ES which I nearly gave up on). I'm also using the cheap Chinese red foam tips from Ebay, but the DIY foam-inside--silicon provides a much better seal.
I used Hearos Ear Plugs - Xtreme Protection Series - 14 plugs for $4 or less! That's about 25 cents a plug. Other high quality foam earplugs will work fine too.
Another option - foam only no silicon. I use the leftover base - cylinder shaped piece of the Hearos. Make a hole in the center, and slip the "doughnut" on the IEM nozzle. Using this method with the EDSE, sound isolation is fair, but SQ is excellent. The foam suspends the IEM in the ear canal, and stays on the nozzle without falling off. It is necessary to compress and hold the foam. There's little between the IEM and your ear.
If you give it a try - please report back - good or bad. Use whatever foam earplug you have lying around first.
