jaydm99
- Apr 2, 2017
From my understanding not all cables are bad. There are some which are faulty and others are just fine. You might want to get the zs6 delivered and if they sound fine then kudos as you just saved yourself 15 bucks.Hi,
I am going to order the zs6 soon. I heard that the stock cable isn't good enough. And I don't like the look of the upgraded braided cables ( it might be weird but aesthetics matters for me as I am going to use these in outside ) I was looking for a red plain cable on the internet but I couldn't one .
I already have a spare red cable ( without connectors though ) do you think I should go the diy ? Or is there someone who could make a custom one with a reasonnable price ( under $15 ) ?
Will these connector work ? https://fr.aliexpress.com/item/UE-p...lgo_pvid=2de5fb4c-4c92-4b08-8ee2-45ee2facb10b
That's pretty.I can tell you for sure the factory ZS5 cable (black sheath covered wire) as well as both silver and gold after market KZ cables have memory wire.
Whats $15 bucks when you are saving $1170 with these KZ , lolFrom my understanding not all cables are bad. There are some which are faulty and others are just fine. You might want to get the zs6 delivered and if they sound fine then kudos as you just saved yourself 15 bucks.
I would like impressions, looking for a bt over ear set for the wife.I always thought the LP3 sound was underrated. Are you going to compare these to any other Bluetooth?
$1170?
9mm according to this https://m.aliexpress.com/s/item/32802844133.htmlDoes anyone know what size driver is used in the KZ IE80?
Yeah man. Multi armature phones used to be really expensive.$1170?
It's was a joke about these ZS6 being a "knockoff" of the $1200 CA Andromeda ...
What if the measurements are the same, and some people just like it? That's possible as well... but! I still think they will be different, that's my prediction!At first I though I got the joke and reference, however then I looked it up and saw that it's $1099 which got me confused whether I what I thought you were referring to was actually what you were referring to.
Anyway, the green one should be here tomorrow or on Monday, so I'll finally see whether it differs any bit from the black (presumably) first (or at least early) batch model I measured.
