Aevum
- May 15, 2007
So i own a ZS5 V1, sounds sweet, no harshness.
So the ZS6 is not an upgrade to them ?
Measurement is important to confirm the modNot without modifications no, the Zs6 is not an upgrade. If it didn't have the 10kHz spike I would say it has tighter bass and a bit larger soundstage than the Zs5 so in some ways it is an upgrade, but the spike makes it very fatiguing after about 15-20 minutes of listening. I am working on damping or filtering one of the BAs to see if I can bring that down. If we can find a good repeatable procedure for reducing that spike, then I think they are worth having, right now they are an experiment.
More than "confirm", measurement can be helpful for understand witch of the two BA produce that peak and if damping that one have some effect on other frequency.Measurement is important to confirm the mod
The newer is this one. It seem oxigen free.I just ordered the ZS6 from Aliexpress. I read that the original cable is not very good so what cable would you recommend for them?
Driver's division and BA's position could make that easy, so i'm convinced that, even if i'm a treble-sensitive guy, we can do it and obtain what we was hoping, even if the need for a mod is disappointing.
Some other upgrade cables
People gonna kill me, but I have to say kz IE80.
Got my ZS6 today from Gearbest. Personally, I think they sound as good or better as than my ZS5. I find no harshness at all.
The included cable is pretty sad looking / feeling. Have them at home on a whiplash audio cable.
This one is said to be for ZST, but other head-fi users use it also on the ZS5.Are there good cables available for ZS6 with a straight plug?
I really like the look of those cables but don't the ZS3 and ZS5 have 0.78mm connectors or am I confused?That's the one I'm using on my ZST Carbon's, going to order a few more now for my Colorfuls and ZS5/6's
Who I ordered my last one from is out but NiceHCK has them in at $8.99
