Most people don't experience any issues with the nozzles. With my unit, I can put spin fit CP-240 (which requires a lot of force to come out of my ears) and it is so firm, absolutely not even close to coming off without some serious pulling with hands. Have no issues with any comply tips, even ones with largest hole, I think it's 5mm or something like that. The nozzle gives a lot of surface area to work with, so even if something was to fall of it, slight modifications to tips could work. Perhaps putting a few layers of clear tape on the nozzle could widen it, this just looks so easy to do.Yeah I was just going to edit after I saw that aliexpress link showing the smooth nozzles. Can anyone suggest a logical reason as to why KZ is doing this?
I had Senn IE800 and sold it because of its bore, try to fit any sort of tips on that thing and you are in some huge problems. Even the original ones started to fall off after some time, absolute garbage nozzle for some serious money. Trust me, ZS5's nozzle is perfect to work with.
As to why they didn't include a small indentation, it was probably because it affected sound in some wrong way, maybe they didn't want to mess with BA driver inside the nozzle, maybe it was just to cut costs of additional manufacturing processes.
EDIT: Just saw that ZST has some sort of a plastic ring on the nozzle, and it also has BA driver inside the bore so, that theory is out of the picture.
