Slater
I love this the thread. To summarize - it sounds like I need a ZS5, zse, and possibly a ZST to cover the bases.
Honestly, if I was in the market for an IEM right now I would skip the ZST and get the ZS5 instead. The ZST and ZS5 are similar, but the ZS5 is superior. The ZST has sibilance and sharp treble that can be piercing at times. The ZS5 is much better in this regard.
The ZST is more comfortable though, I'll give it that. It's also VERY forgiving with regards to sources. It even sounds great with the Bluetooth cable
Also, what 'bases' are you trying to cover? Because you may not even need the ZSE as well. My question would be why are you looking at more than 1? If you want a 2nd pair for the gym/work, or if you're getting them for the sake of collecting, that's fine. But there are other IEMs you may like more than the ZSE.
You could also take the money you would have spent on the ZSE/ZST and instead put it towards a silver plated upgrade cable (and/or the KZ Bluetooth cable) for the ZS5. Then you'd have a very solid and well-rounded setup, with a ton of flexibility to boot.
I'm with you on this thread though - KZ is like crack!
