Mus1c
- Dec 15, 2016
What is this crap i skip this iem for this inside stuff ahhh it ugly y kz y?No crossover, here's ZS5 guts
Confused between getting KZ's ZS3, ZST, and Einsear T2 (thanks to your list @Vidal lol). They're priced just about the same. I prefer soundstage and details/separation.
Dunno about the T2, but I would take the ZST over the ZS3 if you want detailed sound. ZS3 gives a bit of a smoother and bassier sound.
What is this **** i skip this iem for this inside stuff ahhh it ugly y kz y?
You should see the insides of my ZS3. Has twice as much glue as that, gooped and glopped on everything. KZ must buy glue in 55 gallon drums!
So when using them on the stage, one doesn't have to worry if they volume is set too loud before adjusting it?
I was only talking about visible eardrum injuries caused by high pressure, high volumes will damage the hair cells in your inner hear, which is irreversible and might also cause tinnitus, so yes, you need to worry if the volume is too loud.
Back to the topic, you guys that own both the ZS3 and the ZST find them really that different? Is it worth spending 10€ on the ZST if I already have the ZS3?
Heat it up and then gently pry it open with a plastic tool or fingernail - it'll give after it's been heated enough. Generally 70-80 celsius is where you want it to be.How do I safely open up the ZST
Can I ask how you opened the ZS3? I wanna use the shells for something soon. I tried using a "spudger", but it was just messing the plastic up.
Cheers.Explained perfectly here: https://www.head-fi.org/f/threads/k...essions-thread.698148/page-1183#post-13502570
Agree.
@ahmadairfan, you sure that's your only list? If you're looking for big soundstage and details there are plenty of different choices than just what you listed.
