Ninja Theory
I am still tempted to buy this amp in the future. My Kinki EX-M1+ (integrated amp) arrives early Jan. I am confident it will meet both my speaker and Susvara needs but my interest in the THR-1 remains high.
All I can say for now is that I like it very much but it's not an easy beast to tame but I like that being a challenge you have to deserve your reward (like taming a mustang) and it also has it's (small) pitfalls which I will describe in detail in a forecoming review.I am still tempted to buy this amp in the future. My Kinki EX-M1+ (integrated amp) arrives early Jan. I am confident it will meet both my speaker and Susvara needs but my interest in the THR-1 remains high.
I would never try such thing, different impedance level and probably not recommended by Kinki eitherI have a question.as.a.fresh owner is it possible to connect 2 headphonee at the same time ? Tjat would be useful formaking comparisons without switching cables all the time. For instance having a low impedance HP like the HEKSE plugged into the 2nd output jack and another (Susvara) plugged in the XLR output ? Will it work ? Is there a risk apart from the volume level that would need to be managed ?
I dare not try as on my dac/amp combo for instance it is stated that I shall never connect 2 balanced cables at the same time or risk damaging the unit, although I managed to connect one balanced and one unbalanced.
I knew it was a silly question I also asked the guys at Kinki... But it is so tempting, but of course I amI would never try such thing, different impedance level and probably not recommended by Kinki either
You will acquire knowledge with time, this hobby is very excitingI knew it was a silly question I also asked the guys at Kinki... But it is so tempting, but of course I am
technically uneducated.
Based from the below measurement 3.5watts outputs at 300 ohm..Is 7 watts into 30° per channel? So roughly about 3.50 watts per channel into 60°?
So the headphone output impedance is either 50 ohm or 100? Even if I am reading that wrong, I can't find the number from them. If it is not that, does anyone know what it is?The only difference between Phone 3 (also labeled Low) and outputs Phone 1 and 2 is that 1 and 2 have a 50-ohm output impedance, while Phone 3 has a 100-ohm output impedance.
I read it here..
https://www.soundstagenetwork.com/i...hr-1-headphone-amplifier&catid=363&Itemid=444
Make a contact with Kinki's via messenger and ask them anything you want to know..So the headphone output impedance is either 50 ohm or 100? Even if I am reading that wrong, I can't find the number from them. If it is not that, does anyone know what it is?
Thank you. I will.Make a contact with Kinki's via messenger and ask them anything you want to know..
