- Oct 14, 2013
DAC is only a part of the source (conversion side), you will need another part of the source (transport) too
Lost in song when I should go to sleep for work. Dave's depth coupled with the 009 and live music is really unbelievable.
Well, headphone is a limiter, and the amp is the enhancement is the way I see it. You can't enhance any more with a limiter, and that's the headphone. I've realized that the limiter of the Shangri-La Jr system is the headphone itself, not the amp. Ok, in this way we can say a component in the chain is a limiter as well.I have been saying this for a long time now. The headphones make the different too! But to ES, the Amp is even more important, because the Headphones has nothing but layered of electrodes, and the amplifier is what providing the driving mechanism into it. Where as, Dynamic headphones has a huge Magnet attached in it own
I guess people always say headphones since it's is the end of the chain, but if we think of unlimited combinations, it's any component in the chain.
A thing for sure is that if you are touching Kg high-end amplifiers and SR009, everything in your chain will matter
Files quality
Transport
Interconnect cables
DAC
Digital cables
XLR Interconnect Cables
Etc....
There is no simple 1 device that does all
DAVE May be expensive, and perceived by many as High-end, but under some people eyes, it is hardly deserving it price. Switching power supply but not Linear Power Supply, and not to mention the Clock system that it is using. See ? When we are talking about DAC, there are other things to debate, components tolerances, Clock precision and floor noises, power supply.....distortions....etc....There is no single thing
It is a rabbit holes...so Run...Run before you dig deep and burry yourself LoL!
But here is one thing I can tell you all for sure as of why we keep talking about KG amplifiers instead of the rest of the rabbit holes ? Because KG designs are legendary, and then the components being used to build, regardless of different builders, are all good stuff. Then what is so special about KG-T2 ? Because it is another level of components choices and very particular Works/experiences to make it work.
That is why we keep talking about KG amplifier as a starting point for your Stax system, not only that Stax is sensitive to the amplifiers that is driving it, but KG amplifiers are good devices from the ground up. So, once you get either a Carbon, BHSE, GG, or T2, then you can start looking at other components.
Remember, the game will never end
Agreed - but I think it depends on the DAC. Most DAC manufacturers say there DAC's are source immune. Most are not. That said, I'm finding the claims for the Dave to be pretty spot on.
I am using An Auralic Aries Femto with Linear Power Supply, which is by no means a bad source - but I am sure there are better. Honestly, though, it sounds fantastic out of my 2012 unoptimized Mac Mini as well.
With the Bricasti M1 I had completely different story. It had a network card, but sounded dramatically different with a switch between the router and DAC, (which didn't make technical sense to me), and completely different from USB, and completely different from AES/COAX.
I haven't heard dramatic differences in transports - but in fairness have not heard a lot of very high end ones. If only money were really no object![]()
BTW, Whitigir, If I end up going the T2 - your going to be the primary reason why. Your glowing endorsements and my trust of your ears will most likely be what pushes me over the edge![]()
I used to live in NYC, about 30 years ago, but I live in NM now.
Nice! My grandparents still live there, but the city get busier and scarier every year goes by from my experiences...lol
