If you have bass heavy version with bass heavy pads, that could mean too much bass obviously, non-bass-heavy pads worth trying ) But if you listen Thror and Rognir in short session and overall not for long I would recommend to stay with one of them for about a week at least, and then switch to another in a same manner. Let you braind adopt to headphones sound signature and headphones hardware to burn in ) Try fast switching later from one to another, probably you could find mini-burn-in periods, but with mind set to targer sound profile you'll build in your head, that won't take long )) (Probably sound psychdelic, but hope you understand what I'm writing about, that's pure practical advice)
With out the bass heavy pads on they becoming very neutral. The bass heavy pads add a huge amount of bass. So I think I have the neutral version? I don't know. I'm confused now.
I just got a Rognir Dynamic. I like it, but definitely not what I expected in terms of overall sound. I'm going to let them settle in for a while before I make any judgements.
Quick questions?
Is there occasionally rough patches on the wood underneath the laminate? See pic 1 ("scratch" 2 bands under the logo)
Is the old headband style that can be updated if I reach out to someone via PM?
Great-sounding combination. I get my cap-modded QS amp back today and will report the differences between it and stock and how it affects the GH50 JME V2.
Quick questions?
Play with rotating the ear pads around so the angle changes. For me the seal was the best with the seams on the bottom which is the thickest part of the pad. The fit and sound was weird when mine were like yours where the seam is on the back sides
Yes, the photo on the website is misleading...baffling, because the seam at the back creates a notable gap at the front, thus dissolving much of the low end.
