So I just received the K7BT. Can't believe how good it makes my new HD6xxs sound. Details are popping in the music that I've never heard! The bass sounds nice and controlled as well with a nice added thump. Amazing!Then get the k7
[KA3/KA13] FIIO X JADEAUDIO USB DAC DONGLE
- Thread starter FiiO
Dear friend,@FiiO Hi, I got my KA13 yesterday. I have 3 questions:
1. I know that there is a FW update, labelled 0.12, available. However, when launching the FiiO Control app, it says KA13 version is V 2.0.
What does that mean? Should I still upgrade?
2. On your FW download page here, a customer has issue with the FW 0.12: He said "I still hear sudden stuttering, noise, or popping sounds when playing music". Was that issue investigated and should I worry about it? Because for now, I don't have any issue with the KA13 (FYI, my setup can be one of the following: iPhone SE 2020, M2 MacBook Air, Shanling M3X)
3. In case I upgrade and start hearing sudden noise as described above, would you provide me the older FW version to downgrade? (for waiting for a later patch in that case)
1. After upgrading KA13 to V0.12 firmware, you can see that the firmware version number of KA13 is V0.12 in the Fiio Control App. Please check to update the App.
2. Regarding the popping sound of KA13, we have not yet received similar feedback from other users. Of course, we have submitted user feedback to engineers for review. do not worry.
3. We have old versions of firmware. If necessary, you can request it from our after-sales email: support@fiio.com
Best regards
PierreC
Dear friend,
Best regards
Perfect, thanks for your answer @FiiO
Regards,
PierreC
@FiiO
I didn't do the update yet (waiting for a Windows laptop to do it).
But I noticed this in the System Profiler on Mac (please see pic):
Version: 0.12
Does that mean some KA13s were already shipped with the latest FW update? (I ordered mine from AliExpress 3 weeks ago).
Version: 0.12
bru87tr
- May 21, 2016
Looks good!
indoeskrimsakti
@FiiO hallo, I just bought ka13 yesterday. When I'm playing music with format MQA in tidal. The sound in my IEM is broken. But when I played with FLAC the sound is normal. Btw, I have by pass tidal for access my KA13. My handphone is Xiaomi 11T. And firmware for KA13 is V.012.
Thanks
Thanks
Dear friend,@FiiO
Version: 0.12
Yes, your KA13 firmware version is up to date.
If you have an Android phone, you can download the Fiio Control App. After connecting the KA13 to the Android device via a USB cable, you will also see the firmware version number of the KA13 on the Fiio Control App.
Best regards
Dear friend,@FiiO hallo, I just bought ka13 yesterday. When I'm playing music with format MQA in tidal. The sound in my IEM is broken. But when I played with FLAC the sound is normal. Btw, I have by pass tidal for access my KA13. My handphone is Xiaomi 11T. And firmware for KA13 is V.012.
Thanks
KA13 does not support MQA songs. If your KA13 does not malfunction when listening to other songs, it means your KA13 should be normal. By the way, I usually use KA13 with Xiaomi 11 mobile phone, and I am very satisfied with the sound.
Best regards
PierreC
Dear friend,
Best regards
Thanks for your answer @FiiO. It seems my KA13 is up-to-date then. But weirdly enough the version shown in the FiiO Control App (Android) is 2.0 (just to let you know, not a big deal as I see the real version number in the System monitor on my Mac).
PierreC
![IMG_5884.png IMG_5884.png](https://cdn.head-fi.org/a/12222869.png)
bru87tr
- May 21, 2016
I will mention again I was a bit harsh on my initial impressions of the KA13. I really like it and after trying a few of their dongles and devices I think it’s the best one yet. No power limits on iPhone, sounds great and goes plenty loud.
Plus, the limit on the app setting is a plus. As you don’t need an app for setting specific settings. I like the way it was made.
991 Carrera 4S
Thank you very much.Dear friend,@FiiO
Do any of KA1, KA2, KA3, KA5, KA13 support in-line microphone (4-pole 3.5mm CTIA TRRS)?
KA1 supports headphones with microphones (KA1 needs to upgrade firmware 1.2 or above), but KA2, KA3, KA5, and KA13 do not support it.
Best regards
Dear friend,
Maybe your Fiio Control App is not up to date. I connected KA13 to my Xiaomi 11 mobile phone, and I can see on the Fiio Control App that the firmware version number of KA13 is V0.12. You can download the latest Fiio Control App from the following link and import it to your phone for viewing: https://forum.fiio.com/note/showNoteContent.do?id=202105071628040377809&tid=17
Best regards
Dear friend,I will mention again I was a bit harsh on my initial impressions of the KA13. I really like it and after trying a few of their dongles and devices I think it’s the best one yet. No power limits on iPhone, sounds great and goes plenty loud.
Yes, KA13 is a very good product. iPhone 15 mobile phones using Type-C interface can also be used perfectly with KA13.
Best regards
PierreC
Thanks for your reply, but the fiiO app version is the latest available (Android 7).Dear friend,
Best regards
