adriansticoid
Anyone have the firmware file? Can't seem to download from FiiO's link.
Just a moment, please. Disconnect other devices before upgrading.Anyone have the firmware file? Can't seem to download from FiiO's link.
Still can't access.Just a moment, please. Disconnect other devices before upgrading.
I'll send it to you first.Still can't access.
Dear friend,Same thing happening to me. Can you set Google Drive folder to public sharing?
Dear friend,@FiiO hello! I read in comments on your website that FiiO Control App has impedance settings mixed up. The person there is saying that Low is actually High, and High is Low. Can you check it?
https://forum.fiio.com/note/showNoteContent.do?id=202110201505087366118&tid=77
Also If I don't listen to anything for a while it just stops working when I try to play music, so I have to re-plug it into my PC.
1, You can upgrade the V2.0 firmware. Turn off the mute.When I do the sound test in windows sometimes the first sound fades in and the second sound is played normally. There has to be an option to have constant streaming. Some notification sounds are so short they don't even turn on KA3 (or whatever happens to it that it doesn't play short sounds after complete silence).
Removed driver from Windows 11, now KA3 became MUCH MUCH louder. (with driver 60% was getting loud, now it's pretty loud at 10% windows volume).
1. I did upgrade and turned the mute off right away. Now I turned the mute switch on and the sounds stopped fading in but the clicking/popping sound returned. I think the ON is OFF and OFF is ON? What.1, You can upgrade the V2.0 firmware. Turn off the mute.
2, This is just the volume curve is different, after installing the driver curve can be adjusted more appropriately.
Hardware mute switch=OFF. The sound will go directly to the earphones. There will be no delay time to suppress POP. So " the sounds stopped fading "1. I did upgrade and turned the mute off right away. Now I turned the mute switch on and the sounds stopped fading in but the clicking/popping sound returned. I think the ON is OFF and OFF is ON? What.
2. Ok that's understandable.
Yes, but in my case it's the other way around. ON = OFF and OFF = ON. I have no idea why.Hardware mute switch=OFF. The sound will go directly to the earphones. There will be no delay time to suppress POP. So " the sounds stopped fading "
