BoomBap08
- Nov 19, 2016
Yoooo, finally! Thank you for responding @FiiO ! Much love, my guy!Dear friend,
So which product are you having problem when using with our apps?
Best regards
Only the KA3.
Just to reiterate, these are the problems with FIIO CONTROL & FIIO MUSIC apps:
Fiio Control - the digital filters doesn't always reflect your desired option even if you push it multiple times (for example. I choose sharp roll off then exit the app. next time I open the app, the filter reverts back to apodizing.) Using this control app & choosing the filter I want is like playing a russian roulette. You'll never know when you'll get it right or wrong. You have to go back & forth--opening & exiting the app--& head straight to the filter section to rightfully choose the option I want.
Fiio Music - every track I play, whether I literally choose the file randomly or just automatically, sequentially let the files play itself, there's always a couple of seconds (2-4 seconds I think) that skips at the start of each & every song.
