So I'm getting ready to rewire my K702's with a balanced dual entry DIY copper cable. I've done my fair share of soldering in the past, but this will be my first attempt at hardwiring the AKG's. I've read that if you are not careful, that you can overheat/fry the pins on the drivers. I bought a Aoyue 936 welding iron and some cardas solder to try and minimize the risk. I am planning to litz braid the cable and terminate with a 4-pin Neutrik XLR. So my questions are:
1.) Do you have any tips/suggestions when soldering the new cables onto the drivers?
2.) Do you suggest stranded (DHC Nucleotide) or solid copper for the cable?
3.) How did you provide strain relief at the drivers/enclosure?
For those of you who have rewired K701/2's, I am open to any other suggestions.
Thanks
Thanks
