vvaffles
- Oct 16, 2008
i personally can't fully enjoy heavy vocal peices with the k701s, i think the voice is pushed a bit too far back, and it loses its luster.
Man, I can't imagine listening to hip hop with a K601 or K701. But if that light and airy sound works for you, there's nothing else like it. The K701 I believe has less bass than the K601, but I'm not that experienced with the 601. I just know that it is warmer than the 701.
DT880 has more bass than both, and a similar treble presence to the K701 from memory. I would think they would be better cans for hippity hop. Maybe get them both used, and sell the one you don't like as much at minimal loss
edit: what didn't you like about the ms1 by the way?
For vocals and details, go with the K 702, they are more balanced compared to the 880 and they don't have the piercing treble of the 880 and overall more detailed with better depth in the image.
I heard K702 have the same specs as K701 apart from the detachable cable and black paint??
Wakeride, 24 is sick and Jack Bauer kicks arses!
Think I'm gonna get a pair of used K701 to try it out and minimise the loss if I don't like it. The DT880 will probably have to wait until I have a job and can afford a 600ohm manufaktur pair.
I'll also try out a pair of HD600 in the near future, they might replace all K701, HD650 or DT880 as the only one to have. Who knows?!
Well you didn't mention you had an HD650 and liked them. I'd say you should definitely try an HD600. Same general sound as the HD650, but less bass, and more treble. I find that they aren't quite as refined as the HD650, but I think on most budget or modest systems, the HD600 will sound more balanced.
I don't listen to hip hop so I can't say. I try, and I've been recommended heaps of stuff, but I just don't get it to be honest.
+1
Ok, for what you asked:
- Details
- Vocals
- Realistic soundstage
- Neutral sounding
I think the DT880/600 Ohm is a match... but that's to my ears and what I feel is most neutral and natural and detailed and realistic. Also, and it can NOT be dismissed, it is with MY system. So as we say: YMMV.
And... again, I don't feel the same way about the 250 Ohm, or I would have kept them instead.
shane
The K701 has a unrealistic 'tweak' of the extreme left and extreme right soundstages while the DT880 suffers from a lack of soundstage depth. Imaging is better on the DT880.
But yes, the DT880 is more detailed than the K701 + less of a pain to run + more balanced sounding.
Realistic soundstage to a point...both the K701 and the DT880 (no matter what version) have soundstage flaws.
