From another thread: Quote:
Originally Posted by Patrick82 /img/forum/go_quote.gif
...It reminds me of my burn-in experiment with 44cm 22awg Valhalla interconnect where it needed 4+ days of burn-in until transparency appeared. The 1m 16awg Valhalla might need many weeks of burn-in.
After soldering Valhalla power cord into the K1000 drivers I first heard edginess which reduced some low-level detail. After a week of burning in the solder joints it sounded too smooth and veiled but there was more low-level detail. But after 3 weeks or burn-in the low-level detail + transparency started to appear just like with the 22awg experiment. It appears that a 16awg conductor needs about 6 times longer burn-in period than a 22awg conductor.
Having Valhalla power cable soldered into K1000 drivers are uncomfortable, I can't move my head or look down at my keyboard when I type, just writing this sentence took a couple minutes.
It's not uncomfortable anymore because I got used to it.
I believe the thinner Odin is the better choice. I asked a dealer if he can sell a single cable and he can! I could order a very long cable of the Odin and re-wire everything like I did with Valkyrja! Odin will give crazy speed!
I get too much bass from K1000 now. It makes HD590 sound thin and empty in comparison.
I get more bass now than before, but the bass isn't in the way of the rest of the music like it used to be before burn-in. The blackness and whiteness is crazier than ever! The soundstage is huge and clean. There is a new world of low-level detail. I believe the Valhalla power cord soldered to K1000 is the best value in audio because you can get the Odin performance for much cheaper. It has the same Dual Filament technology except the conductor thickness and silver plating (70 microns) is different. I'm not hearing any reduction of speed from the 16awg conductor, upgrading to 20awg or 23awg Odin (85 micron) would probably make it worse because of the deeper silver plating which reduces low-level detail to gain fake transparency (based on my 60 vs 78 micron experiments).
I remember my first impressions of the 16awg Valhalla for my K1000. The 70 microns silver plating appeared to be perfect for a single conductor. It had just the right balance of low-level detail and transparency. 60 microns sounded too grey and 78 microns sounded too edgy. The 85 microns Odin I haven't heard, but based on logic it will sound worse when using it as a single conductor. I'm not willing to spend <30 times more to find out.
The 16awg 70 microns Dual Filament Valhalla power cable sounds crazy black and white with huge bass and low-level detail. I didn't think improvements this big were possible in audio. I have tried stock K1000 cable, Stefan AudioArt, Nordost Solar Wind, Nordost Valkyrja, and Nordost Valhalla. Replacing 35cm Valkyrja with 1m Valhalla made a bigger improvement than all of the other previous steps combined because it was a huge bottleneck. The cable needs to be re-wired all the way to the drivers. I'm in love with Valhalla.
With all the previous cables I tried I have heard weaknesses. With Valhalla I hear a weakness too, but that weakness is burn-in. Having music running through it 24/7 is a must because the conductor is so large, otherwise it starts sounding veiled after a while. I wonder if periodically using a cable toaster will give further improvements. It's not a coincidence that Nordost are selling those cable toasters. They know what they are doing.
