SAC amp = yum.
Vintage Marantz amps = yum.
Hi, I have to add some thoughts about using any Tripath amp with the K1000: All Tripath applications show an output filter usually designed for 4 Ohms loudspeakers. If you use this application with an 8 Ohms loudspeaker the ripple in the frequency response will be around 0.5 dB which is rather unproblematic. If the amplifier is measured with _open_ outputs the peak at 20kHz reaches a value of around 30dB(!) which would be more than unacceptable. Nevertheless I assume that with the 120 Ohms of the K1000 (factor 30 compared to the filter's calculated load) you will have a treble peak of several dB which is more than just a nice coloration. To use an AKG K1000 with such a Tripath based amp one should shunt the amp's outputs with 8 Ohm resistors to avoid the high frequency peak. The same resistor will also reduce the energy in the 100kHz - 1MHz band where the switching frequency is wandering dependent on the power drawn from the amp but this is another effect. |
Originally Posted by Tyll Hertsens We've got the VolksAmp version of the Pass designed Aleph 1. I like it just fine with the K1000. I think the K1000 NEEDS a VERY good amp to really bring out what they can do. Under-driven they sound pretty poor. |
Originally Posted by Hirsch It's not a question of impedance, so much as power. Typical headphone impedances range from 32 ohms to 300 ohms, so the K-1000's 120 ohm impendance is right in the ballpark. However, the K-1000 is very inefficient compared to most headphones, and normally requires a speaker amp rated at 7-10 watts to drive them. However, that rating is normally into 8 ohms or so, so the real output needed would be the wattage of the same amp into 120 ohms, which is a bit less. Some headphone amps have enough power to drive the K-1000 (but fewer will drive it well). There are some good suggestions in this thread. |
Originally Posted by Uncle Erik I've gotten halfway decent sound from a Denon receiver and the PreSonus Central Station. I know, I know, you're not supposed to use those with the K-1000. |
