ronaldo7messi10
- Jan 28, 2013
I shoulda bought these when the price dropped!!!!!!
It's finally HERE and in my ears!!! And YESSSSSSSSSSSSSSS!!!!! :etysmile: This is how I dreamed (wished) the FX700 would have sounded like when I first had them. The bass sounds about as big as I remember in the FX700, but tighter and moe refined. The hot treble has been toned down some to my liking. I think the overall sound is a bit more refined. In freakin--- credible sound, but one that I was familiar with the FX700, but the FX850 takes it to the next level. And NO RECESSED MIDS!! <<< my biggest gripe with the FX700. Wow wow wow!! Yes, I'm hyping them!!
Now I happen to have the AS-2, and I think it keeps up with the FX850 with vocals (thinking this may change with the woodie burn-in), but the FX850 is otherwise ahead of the game. And I've heard no dynamic fast other than the TE-05. Huge wide sound! For $300 it's actually a BARGAIN fellas! If you can find it at $288 to $300 don't hesitate, but it's worth $400 easily in sound too. Happy listening indeed!
And ooooh that timbre! Nothing else like it in an earphone.
I think the FX850 may actually have a bigger sound than the FX700.
This is an audiophile basshead's wet dream! I'm just saying.
You kinda sound like Dsnuts with your enthusiasm lol. Must be really good. What would you compare the sig too that's lower tiered than these? Also, how do they compare to DUNU-1ks and H3s?
gushy FX850 goodness
Nothing has its timbre that I can think of. Some of the clarity and transparency of the TE-05 are bit familiar with the two, but sound sigs totally different. Will listen to the H3 later to compare. The DN-1000 doesn't come close in any way I can think of, but I don't have those anymore.
To me, transparency not only implies clarity, but also an absence of major FR bumps and dips (i.e. coloring).
i see, should be somewhat identical to loose seal then, makes it like the ambriose tip Rin made a while back perhaps. I personally don't like how loose seal/tips like these tame bass, but ymmv. While covering the back vents may make the bass sound dull, that pinhole may make all the difference.
Why mod perfection
It's finally HERE and in my ears!!! And YESSSSSSSSSSSSSSS!!!!!This is how I dreamed (wished) the FX700 would have sounded like when I first had them. The bass sounds about as big as I remember in the FX700, but tighter and moe refined. The hot treble has been toned down some to my liking. I think the overall sound is a bit more refined. In freakin--- credible sound, but one that I was familiar with the FX700, but the FX850 takes it to the next level. And NO RECESSED MIDS!! <<< my biggest gripe with the FX700. Wow wow wow!! Yes, I'm hyping them!!
