Just got Sansa Clip+, to rockbox or not to rockbox?
Jun 16, 2012 at 6:10 AM Post #16 of 107
Thanks.
Anyway, why does my Clip+ sometimes tell me there's no .rockbox directory? Only sometimes, which I feel is weird. Sometimes, it hangs on the Rockbox screen. And sometimes, it works flawlessly.. Why can't it just be flawless all the time!
The .rockbox folder is right there when I open my player on my PC.
Have reformatted and reinstalled both OF and RB on my player multiple times to no avail..
Anyone able to help?
Try using the auto installer from rockbox if you haven't already. That's how I did mine.
Sorry to hear you're still having a problem
Jun 16, 2012 at 8:12 AM Post #17 of 107
I'm using the latest stable build, 3.11.2 I think.
Anyway, I've never connected the player to PC in RB mode cause I did it once and the device driver installation or something failed and I never tried it again.
However, yesterday, I accidentally connected my player to PC forgetting it is on RB mode, this time the driver installed successfully, and 2 additional folders appeared in the player's root folder. "##MUSIC#" and "##PORT#".
Been working flawlessly ever since, been turning the player off and on about 10 times now, both to test and to listen to music, working perfectly.
Funny that I've been looking for help all over the place and it gets fixed by a fluke.. Thanks for all the help, fingers crossed that it keeps working :)
Jun 18, 2012 at 7:16 AM Post #18 of 107
Okay, after a couple of days of working flawlessly, giving me the exact same **** again.
Never touch any settings or files, never mess with anything at all.
Getting real frustrated >.>
Jun 18, 2012 at 2:05 PM Post #19 of 107
I am glad I stayed away from Rockbox.
Jun 18, 2012 at 2:37 PM Post #20 of 107
I'm afraid not. Your issues are an absolute mystery to me.  The RB devs are rather conservative in their classification of builds as "stable" or unstable, and the Clip+ port certainly lives up to "stable"....once it hit official stable status, I ran it on two of them for many months without a single issue, only selling them when I got the newer model, the Clip Zip.
Jun 19, 2012 at 4:44 AM Post #21 of 107
To me as well. Have reformatted and reinstalled many times.. Sigh.
When I play files in OF, files tend to get skipped as well. Nothing wrong with my files.
Could it be player problem? Hmmm..
Jun 19, 2012 at 8:03 AM Post #22 of 107
Are you sure the files are in a format the Clip+ supports? Some people try to play AAC files or other Apple formats on the Clip+. That won't work. If the files are protected WMA, they must be transferred to the player using Windows Media Player or using another media player that supports license transfer and also use MTP mode . If you ripped the files from CD using Windows Media Player, the default format for ripping is protected WMA. If you did rip CDs to protected WMA, I suggest you rerip them to mp3 using at least 192 kbps. Some protected files like subscription music or protected audiobooks might need to be transferred to the player using the  software you used to download them. Some protected files might not play properly from card memory, and need to be in main memory to work properly.
Are you sure your tags are okay? For mp3 files, the Clip+ needs ID3 V2.3 ISO 8859-1 tags. if your tags are different than this, the Clip+ may have problems.
Jun 19, 2012 at 9:17 AM Post #23 of 107
Positive.
I would like to repeat that it works flawlessly sometimes, every song plays the way it should.
The most frustrating is it sometimes tells me no .rockbox directory found, when it is right there. Only sometimes, not all the time, which is extremely confusing to me
Jun 19, 2012 at 10:49 AM Post #24 of 107
Perhaps you should try to get rid of Rockbox and start over if you can, next time avoiding Rockbox.  I would suggest exchanging it and getting another Clip+, however they might not take it back with Rockbox on it. Sandisk may not exchange it either with Rockbox on it.
Jun 20, 2012 at 7:05 AM Post #25 of 107
Yup, every conceivable troubleshooting step short of exchanging, I've tried it.
However, I do notice that the .rockbox directory not found error does not come up when I start up without the microSD inside, so a quick fix is to start up without microSD, then off and start again with it.
Working alright since I did this, hope things'll be fine now.
Fingers and toes crossed.
Aug 27, 2012 at 5:45 AM Post #26 of 107
Guys,
There is any microSDHC compatibility list regarding cards which work with Sansa Clip+ with latest Rockbox installed?
I'm planning to buy a 32GB microSDHC card from Samsung... would it work in this size? Anyone has tested a 32GB card with Clip+ and Rockbox and can confirm me a product part number, to make sure what I'm buying?
Thank you,
Andrei
Aug 27, 2012 at 6:02 AM Post #27 of 107
Guys,
Thank you,
Andrei
You will be fine with any 32GB micro SDHC card. Class 10 is best.
Aug 27, 2012 at 12:05 PM Post #29 of 107
Emospence,
I don't have a clip+, but from what i've read, your memory may be a bit faulty or not really compatible with RB. This kind of thing happened with me with 2 of my cameras(sometimes the camera would read it, sometimes don't, after some months the memory stick totally stopped working), my old PSP, and i even had a problem yesterday formating a pc (turned out the PenDrive i was using couldn't boot, so i took a SanDisk one and worked flawlessly)
Can you test it with other card? i found out that the only way to avoid things like that is to buy quality memory (like the ones from SanDisk)
Aug 28, 2012 at 2:12 AM Post #30 of 107
Guys,
Thank you,
Andrei
hey there
I'm using a rockboxed clip+ with a 32 GB sandisk microsdhc card  it works flawlessly but you should reformat it BEFORE using it with a file allocation size of 64k, otherwise the clip+ will randomly freeze.
have fun with it ;)
