devouringone3
Yes, but I've never made any soldering (I added a line specifying it among my images)! I would prefer to have it done by a professional. And while I'm at it I've been checking cables... if ever Joseph is too busy to take care of my HP2 and upgrade it, I will use a balanced Cardas clear headphone cable, and ask either Drew, Alex, Larry or Rhydon to do recable it for me! I will pay them anything.
I wanted a high-end Double Helix Cable but these are simply too big to fit. Cardas clear doesn't look handcrafted so it's a lot thinner, I will also ask that the recabler tries his best to fit some kind of protection (heatshrink, of course we need to try this) (if not, some kind of tape, just like I was doing before it broke; Scotch Tough duct tape seemed to be the best, before I break my joint) for the cut-outs, mines are so sharp that they dented my cable everywhere it stood on it, while I manipulated the driver and tried to tape that weak and exposed to denting portion of the cable.
For strain relief yeah I would suggest a tight-wrap (zip tight) and maybe a dab of epoxy behind it and against the cable.
I picked Cardas because it's the most expansive cable I could find that would most likely fit inside it... I would have picked Spore from DHC if it could fit. For the best headphone the best cable! HP2 and HP-1000 driver in general is my best and favorite thing to listen to.
I will do it in the summer, right now I'm low on money.
Thanks Mr.Sneis for trying to help me You're putting it very optimistically and it helps me cope with the idea that I just broke a brand new (old stock) and rare 2000 dollar headphone.
What pisses me off is that I didn't even let it time to break naturally... and the fact my headphone was on his first cable, which I think in some ways is always the best one, because it is affixed to a unused solder pad and a unused driver.
I'm not clear if you can solder or not but you now have the opportunity to re-cable with something else easily DIY-able where you can beef up the strain relief with heatshrink or something. You can re-use the cable or solder a new one on. Inside the stock Grados I have seen, the strain relief is either a zip tie with slack inside the cup or hot glue. You're essentially halfway there already!
