Now I have found the ability to add files and images I’ll sort a few out and give some initial feedback on the XTC-c 2.5 Trip’s.
Build quality.
If I am honest, you can tell these are hand finished and not a “Production” set of phones from one of the big players, that is not to say the finish is poor in any way! The fit and the finish is superb but on close inspection you can see the work that has gone into making these a bespoke set of headphones. For me that’s a bonus not a negative. For those of you that want a B&O type build then these may not be for you.
One of the attractive elements of these headphones is the opportunity to get a set built the way you want!!…. And that’s exactly what you get!…
I must say the process of ordering and then being walked through the build is superb and once again goes towards making this feel like a true custom experience and gives you the confidence that you are going to get something to be treasured at the end of it.
John and I must of exchanged in excess of 50 messages, which considering the time difference (UK - New York) meant John was definitely pulling some long days and going above and beyond to ensure the spec was nailed down and expectations were met.
So, build experience… spot on!!
Customisation and accessories…
What can I say, the level of detail given to each aspect is beyond reproach and once again John walks you through the stages, giving a good selection of options.
Personally I was happy to go with the recommended pads but because I wanted to use the headphone in three differing scenarios (Lounge, on main system, desk top and then mobile) I wanted three very different cables. I am not so much interested in what the cable was going to add or detract sonically, that’s not my thing and not a rabbit hole I want to discuss!) but rather differing lengths and termination types.
John was absolutely able to accommodate and if I am honest gave me what was a frankly ridiculous deal on the cables.
Having completed the build and spec and then the accessories… the item was dispatched…
Full tracking information provided and I must say the servcie from ups was trouble free. The headphones were in my hands in a matter of days and to the hour they predicated.
There was an import fee to pay but was gentler than might of been and easy to pay online so I didn’t have any issues with the items being taken back if having to pay on the door.
Upon arrival, there was a minor problem of how to unpack the parcel!!!! John does know how to pack!!!!… feck me
… you may want to consider the purchase of a sharp and robust pocket knife to gain entry into the packing!!
If there is any packing tape left in New York I would be surprised!!!
So as you can imaging the unboxing was an impatient affair but resulting in the contents being delivered in perfect condition!!!
The “Pelicase” type container is perfect for the job and is reassuringly robust giving your pride and joy the protection they deserve whilst not being so heavy as not to be of use.
So overall the purchasing experience and the delivery has been second to none and has exceeded expectations.
So what do they sound like!!!
Well if I am honest I am not so comfortable talking about that… yeah I know a cope out, but when I read headphone reviews I hear a language used that I am simply not capable of reproducing… I cannot describe with that sort of elegance what it is I hear. I cannot conjure that level of sonic imagery…
I will give this area some more consideration and post more…
Impressions to date…
They sound as good as hoped and better than I expected…
I have grade GS1000’s, Meze 99 classics, sennheiser ie900’s and b&O H95 as my comparisons. (Plus many many others over the years but these are my current users
Sources
Lounge
Roon
AVM CS 8.3 Ovation
Desktop
Roon
Burson playmate 2 vivid v6 op amps
Mobile
Astell&kern SR 35
Across all these setups I am experiencing sounds I have not heard before, so the detail and resolution is there!!… which is the tuning I wished for. Bass is crisp… impactful and non intrusive… heavier than I would have imagined but because of its definition its is not imposing or detrimental in any way.
Overall this is the most enjoyable and musical set of headphones I have owned or auditioned to date.
But don’t take my word for it…
Go buy some, then tell me how you found it
Well that’s enough from me…
I’ll perhaps give a further update and pictures when I’ve a few more hours listening under my belt and can find some more eloquent way to describe what it is I experience.
Overall, fantastic experience, John builds the confidence of the purchase at every stage of the process. Sonically they have exceeded my expectations and offer incredible enjoyment for what cannot be a sustainable price point!!
You can hear the pride John takes in these, and it’s warranted!
Greig.
