tourmaline
- Nov 10, 2003
You are defensive, claiming that reclocking doesn't work, not the general experience, is it. Did you use a dedicated powersupply for the clock? It suppose to significantly raise the sound of reclocking.
Probably the reclocking works better on older cdplayers then newer ones, since they are likely to have worse jitter specs...
Originally Posted by regal /img/forum/go_quote.gif I have built several DAC's, experiemented with different recievers like the DIR9001/CS8414, used reclocking. I am just asking a question, you are very defensive. |
