shotgunshane
- Sep 25, 2010
I've noticed that the way my silicones are now installed and the way they came installed is that they're flush with the end of the nozzle.
Just the way you guys created the same effect by cutting your foam tips in your photos. The silicones create zero overhang. No silicone exists beyone the nozzle.
Depending on the diameter of my earcanal there might be close to no silicone to reflection too, given that the nozzle is pretty wide with the three bores. The nozzle will take up 95% of the room and the silicone surrounding it might be very small depending on the ear canal size and insertion depth.
What I'm saying is that the effect of the silicone tip on sound can be minimal and might not be all that different from what you comply/shure foamy guys are trying to achieve because of my ear canal shape and size. We may be hearing very similar kind of sound.
But yeah... all of this is very interesting dicussion. I'm glad we can get a good taste of what the customs might sound like
Yeah the silicones definitely sit low on the nozzle; more so than most universals. I can see what you are saying, especially if you have narrower canals and don't need the larger silicones to fill canal width.
