mashuto
- Sep 23, 2016
I did end up getting a refit. Though I don't know if there's a specific difference between what you are referring to as a refit or a retouch. I think they refer to a refit as just touching up the fit, not building whole new shells. But I could be wrong.Mashuto, thanks for catching me getting ahead of myself. I'll leave it up to the guys in Orlando to figure what is best. As far as the future timeline goes, I understand a retouch is very quick, but if I was to end up needing a refit, would I end up waiting the same time as the build or is the process expedited? If I remember correctly, you had some back and forth with yours; did you end up getting a refit? If so, what was the timing with that?
The process for me was that I reached out to JH and explained what I was feeling and let them sort of guide me towards what they thought needed to be tweaked. Though in your case it's pretty obvious, but they will likely be able to tell you in more detail if they think simply trimming down the ends will cause other problems or not.
For mine, I had them add a little material to one spot and trim some from another spot just a bit. From when they received them back it was maybe 3 or 4 days. So total time with shipping on both ends was I think just over a week.
