rckyosho
- Jan 4, 2013
Or you can use a sound level meter if you have one which is easier.
I purchased a 40x3 pack of straight header pins from Fry's Electronics (it was only $1.99 USD), and it looks like they'll fit right-in with a slight trim. I'll soldering later when I get the.......
Initial comparisons between the C5 and the O2, to me at least, the O2 has a larger soundstage with better instrument separation, the C5 has more bass (though I admit it is hard for me to properly volume match).
Quote:Initial comparisons between the C5 and the O2, to me at least, the O2 has a larger soundstage with better instrument separation, the C5 has more bass (though I admit it is hard for me to properly volume match).
I think that you should give the C5 some hours of "burning in" before you do a serious comparing.
To compare a brand new C5 amp to your O2 (that I guess have "a few hours" more of use) is in my opinion unfair.
I'll guess that around 200 hours with the C5, it will "open it up" a bit.
I have now placed an order for a C5 (silver), and hopefully I will recieve it sooooon!
I can't wait.. I am looking forward to get to know this little amp.
To me the O2 and C5 sound very close to each other, but the O2 still sounds a bit more spacious and instruments seem more dynamic with more air between them.
Not to say the C5 sounds bad, I think it sounds fantastic and is a really great amplifier for portable use, sensitive headphones, and for low-volume listeners (such as myself).
Where are all the impressions and reviews?!
Well then, my multimeter doesn't have small enough AC voltage increments for portable headphone amplifiers, so I tried to volume match the best I can with a 1 kHz sine wave generated from Audacity.
Setup:
MacBook Pro Retina Display (source) -> Audirvana Plus media player (hog mode and integer mode on) -> JDS Labs ODAC -> -> JDS Labs C5 and JDS Labs Objective 2 (using a V-MODA SharePlay cable as a cable splitter with another interconnect cable)
I switched the headphone cable between the headphone-out ports of the O2 and C5 for A/B testing, switching times were less than 1 second using a V-MODA Crossfade M-100 as my headphone of choice (it's my go-to headphone for portable use).
Test tracks:
Daft Punk - Robot Rock
Ottmar Liebert - Snakecharmer
Massive Attack - Teardrop
I Ching - Beauty is Everywhere (24/96)
Beth Orton - Magpie
Not to say the C5 sounds bad, I think it sounds fantastic and is a really great amplifier for portable use, sensitive headphones, and for low-volume listeners (such as myself). Given the choice between the C5 and the O2 for a portable headphone amplifier, I wouldn't hesitate to recommend the C5. I also LOVE the bass boost for the AKG K 701. Don't forget about the re-programmable digital potentiometer too.
I posted mine in a few posts up:
I'll be at school all day so I won't be able to do much listening for the time being. I ordered a FiiO E3 so I'll see how things sound with an iPhone as well.
I saw yours and one other guy posted as well. Only 2 tho! Bunch of people must have received theirs since JDS started shipping them....I ordered mine yesterday but I guess I'm just too excited and can't wait for more impressions!
