Happytalk
- Oct 1, 2014
Definitely something wrong in the chain.
Just curious. Just how powerful is the C5? I have one, powering low ohm IEMs at the moment. But what about something like DT770 250ohms? Or 600 ohms? What is the C5's limit when accounting for powering power hungry cans?
I suspect the Note 4 and its current os simply cannot support usb audio. Research your rom if it really support usb audio natively.
Hibymusic uses its own drivers that is why it works.
it's not a total deal breaker, you just need a rom that is known to provide usb audio natively. Cynanogenmod has been known to support it.
Still it is phone specific. So do your research so you avoid barking at the wrong tree.
In my research Note 3 is known to support usb audio natively. In fact, the Note 3 was on my shortlist. I ended up buying an HTC M8. USB audio works
natively.
Dose anyone use the C5D with a Note 4 over USB OTG?
I just got a C5D and JDS Labs OTG cable and tried it with my Note 4. The Audio is horribly distorted. You know how in movies the bad guys uses a device to distort his voice? That's what it sounds like, with a bit of slow motion going on. With the HibyMusic App I can play my music, but other music app and streaming apps (Spotify & Pandora) are distorted and horrid. Same results with the Galaxy Tab 2 8.4 (actually it sounds worse!).
Just tried it with my Note 3 and it works fine. What's the deal with the Note 4? I'm assuming it has something to do with Samsung's implementation. Work around/fix?
No new Samsung devices work properly w audio OTG. I've tested the Note 5, Tab S 8.4, Tab S2 8.0, and two different galaxy S6 models and all exhibited that distortion out of both my HA2 and my C5D. It's a Samsung software issue clearly as every other device I've tried works fine.
Is the c5D worth $90 more than e18 fiio (sale on mass drop)
