ufospls2
- Dec 9, 2014
I love the sheen on the driver. All green and purple! Hope I can hear these some day
This is the tour from Hifiman.
I will handle more tomorrow. I will burn these in overnight.I am also part of the North American tour. Eventually your pair will make it down to me
Please make more impressions. Also have you ever heard the HE6 before? if yes, need to know if it sounds the same or more refine and advance? Also more pictures please.
@jamato8
Here is a rare impression on my take on JADE 1:
Original JADE - presentation very tight, the control and the bass and mids tight and controlled.
The bass is there but not overwhelming, but is tight and controlled. I find the sound in your face but not impactful enough that is overwhelming. Because the sound is in your face, i find these have a small soundstage. The stage is just around you. And this can make this narrow and focus. But at the same time its very deep. And this leads me to the second best things about this headphone. The imagining and the mircodetails. Its on point and correct and accurate. Because of that, you can pick up all the small sudden detail on the left and right at micro levels.
@jamato8 onces you are ready can you compare everything I said about the original and see how the JADE II compares? And expand whats change?
Thanks
This is the tour from Hifiman. I'm pretty sure I'm first here in US. They are brand spaking new.
Innovating the art of listening.
Stay updated on HiFiMAN at their sponsor profile on Head-Fi.
How many hours should I get on it before it opens up all the way?Yep, I can confirm your one is a brand new, fresh off the boat Jade 2 System.
Mark
10hrs. after 10hrs any other changes are more of a brain burn-in. Although my Shangri-la Jr only needed a couple hours and no further changes.How many hours should I get on it before it opens up all the way?
Too bad it's super weak. But the build is like a mini tank.For me, there is a further refinement and a bit of opening up to around 50 hours. This is in comparison to other amps and phones so I have a baseline to go from and avoid the "brain" burn-in. Out of the box, the Jade II amp and electrostatic headphones sound good.
I have to say, that this is the 1st amp that my wife has said a number of times, That is a nice looking piece of equipment. She never cares and doesn't listen to headphones no matter how good the sound but she does admire the looks of the amp, so good going HiFiman on that! And I agree, it is very, very good looking and easy to work with.
What is super weak?Too bad it's super weak. But the build is like a mini tank.
I have to max out the volume knob to get to a decent volume level.What is super weak?
That would be the input voltage then. That doesn't mean the amp is weak. Possibly more gain is needed for the source you are using or for the source, have a higher voltage out. I am listening to some Neil Young, Unplugged at around 11 to loud at 12 so there is a lot of travel left. On recordings that are recorded at a low gain, do have to go higher but that isn't the amp being weak.I have to max out the volume knob to get to a decent volume level.
