@brooko tell me/us more.
Did you download the equalizer app or EQu app for your itouch4G? (there are two different ones).
How does it compare to your Cowon now that you have an eq option for the itouch?
were you using an amp before and If so which one?
Thanks. You are the perfect active guinea pig. cowon + itouch4G and new to head-fi.
Hi Expat
I looked at both - but downloaded Equalizer. It's
really nice being able to manually tweak the touch.
My only reason for getting the touch was that I was able to use some excess air-points instead of cash. I love my iAudio7 to bits - but it's only 16Gb, and my FLAC collection is already well in to the 60GB range. So basically by getting the Touch - (and converting to ALAC) I could still run lossless - and carry more music.
I've only really got back into my music over the last 18 months. Started with a cheap Philips player and Sony headphones. I got serious about it 12 months ago when I bought my Shures and the iAudio7. Unfortunately everything in NZ is horribly expensive (Audio) - so it's a hobby I have to take very slowly. Case in point - the SRH840's I'll buy in a couple of months are $400 NZD here - but I can pick up in the US for ~ $170 USD ( = $220 NZD). The Cowon J3 is about double the price here as well - hence my first time with an Ipod Touch.
As far as comparison iAudio7 vs Touch - to my ears the Cowon is a lot clearer and a lot warmer. Mind you - I'm comparing the Cowon with a very mild EQ but including some BBE etc. It definitely helps the clarity in the vocals. The difference now with the EQ on the Touch is that at last I have some manual control - and already I can get more sparkle into some of the tracks - and they definitely sound better.
I've never owned an amp/DAC - but with the money I didn't spend on the Touch - I have an option of getting something reasonably cheap like a fiio e7 + a LOD. I'm tempted to do it - even though it's probably not needed for the HP/IEMs I intend to use - because I'd just like to see if it makes a difference. I figured $100 USD wouldn't break the bank - and it would be nice to know.
The biggest dilemma I have at the moment is whether to sell the Touch in NZ and get a J3 when I travel. The advantages are:
- I know the Cowon SQ - and the EQ is second to none IMO
- Expandable SD slot - so getting either a 16GB player then adding a 32Gb card later gives me min 48Gb
- They do FLAC. I use linux at home - so then I could ditch iTunes.
But the temptation at the moment is to keep the Touch (at least for the next year), play with the EQ in the meantime (and I think I can get it close to perfect for my listening tastes), and get the Fiio + LOD (just so I can see if it makes a difference). The more I consider it, the more I'm inclined to hang onto it for now. I can always get the J3 later in the year if I save my pennies.
I'll be traveling late March - so if you are still interested in feedback in April - I can let you know how the Touch + Fiio E7 goes.
BTW - the Equalizer app is really easy to use. And you can get very refined settings by tapping the numbers up the top, and inputting exact details using the touch keypad - rather than using the sliders. It really does make a difference too!
