Sounds like a ground loop issue. Disconnect the AC adapter and try battery instead - if the buzzing disappear, that will confirm it is ground loop. It should be fixable by using a ground loop isolator or an USB isolator.
Have a quick "normal or not normal" question on my JDS cmoybb.
When I turn it off (still connected to Schitt Modi DAC), there is slight buzzing sound in my headphones. The sound persists - it's not transient.
No sound at all when the switch is on but at low volume.
Running off mains power (non-rechargeable version).
Any help appreciated - thanks.
